Preprocessing
Preprocessing
How to establish different intensity of mesh in single part?
    • wangwang
      I attach my ideal result of mesh in this post. As you can see, the mesh in the right side corner is much more intense than other area. I know I could realize similar function in such a operation order like: mesh-definition-type-sphere of influence, however, in this way, the domain would be a sphere, instead of a rectangular shape in the picture which I attach.
      Anybody could give me some inspiration? Thank you.
    • peteroznewman
      In the Geometry editor, say DesignModeler, create a new plane, where the Z axis is up and at the level of the change in density and slice the square body into 2 pieces, a top and bottom piece.  Now create another new plane where the Z axis is horizontal and the XY plane is aligned with the other change in density along the X axis. Slice the 2 pieces again to get 4 pieces.  Now highlight those 4 bodies and Form New Part to share topology.
      Now in Mechanical, you can add mesh controls.  Use Face Meshing on all 4 pieces, then add Edge Sizing on the two sides of the high density square and Edge sizing on the two sides of the low density square. You should get something very similar to what is shown above.
    • wangwang
      Thank you. I already successfully solve the problem based on your way.
    • peteroznewman
      Great!  Please mark my post with Is Solution so the topic gets marked as Solved.
Viewing 3 reply threads
