March 6, 2021 at 7:55 pm
rogerio6497
SubscriberGood afternoon everybody. I would like to estimate the heat flow [W / m ^ 2] versus time [s], entering the available experimental temperatures [?C], for two temperature sensors, in a notepad file (.txt). I already do this in COMSOL Multiphysics and use the levenberg-marquardt algorithm. Can anybody help me? I intend to use ANSYS CFX and modeFRONTIER. I have the heat flow [W / m ^ 2] versus the time [s] measured experimentally. I appreciate the attention.n -
March 9, 2021 at 7:01 pm
Surya Deb
Ansys EmployeeHello, nIf I understand this correctly, then you could potentially use the Profile Interpolation functionality in CFX to do this. nEssentially, you could provide your experimental data in a csv file and then use that to generate results.nYou will find more information about profiles in the link below.nI hope this helps.nRegards,nSDn -
March 16, 2021 at 10:20 pm
rogerio6497
SubscriberHello, If I understand this correctly, then you could potentially use the Profile Interpolation functionality in CFX to do this. Essentially, you could provide your experimental data in a csv file and then use that to generate results.You will find more information about profiles in the link below.https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/cfx_pre/i648521891.html?q=ProfileI hope this helps.Regards,SDhttps://forum.ansys.com/discussion/comment/110063#Comment_110063
Good afternoon, can you send me the text? I was unable to register on the ANSYS website. Thanks.n -
March 17, 2021 at 4:29 pm
Ansys EmployeeYou don't need to register, https://forum.ansys.com/discussion/22563/using-help-with-linksn -
March 17, 2021 at 9:08 pm
rogerio6497
SubscriberYou don't need to register, https://forum.ansys.com/discussion/22563/using-help-with-linkshttps://forum.ansys.com/discussion/comment/111238#Comment_111238
Sorry but it didn´t work out.nnRegards,nSD -
March 17, 2021 at 10:40 pm
SubscribernYou have to copy the text of the link and paste it into the address bar of the browser that was opened when you started ANSYS Help. Below is the text of the link as text instead of a link, which makes it easier to copy and paste.nhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/cfx_pre/i648521891.htmln
2656
2120
1347
1118
461
