March 13, 2021 at 12:39 am
Guanhui Wang
Ansys EmployeeHi. FDTD Solutions uses a time domain solver. The simulation starts by inserting a short optical pulse into the simulation domain (through the source) and it runs (or should run) until the optical signal passes through the simulation domain completely. This means that your simulation time should be large enough so that the light from the source is able to cover the entire distance from the source to the end of the simulation region.
For example, if you have a simulation setup where the optical signal will travel for 5 micron before leaving the simulation region and the material has an index of 3.5 then the time required for the light to travel this distance is given by, t = 5e-6/c*3.5 sec = 58 fs. This means that a simulation time of at least 58 fs is required.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1285
1096
459
