February 9, 2022 at 5:32 pm
Thekkan
SubscriberHI,
I was trying to simulate a WPT system with one transmitting coil and 2 receiver coils(a 3 coil system). I know how to do a 2 coil system, in a 3 coil system case, I don't know How to assign excitations. Kindly help me.
February 16, 2022 at 8:53 amNavya C
Ansys EmployeeHi @Thekkan Can you share some screenshots of your model for a better understanding of the coil arrangement?
Generally, you can excite the other coil the same way you did for the first coil.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
3670
2550
1749
1226
582
