Systems
Systems
How to export a ‘.lib’ (spice) file from a circuit in simplorer/ circuit?
    • Rui_Pardal
      Hi all,
      I'm modeling capacitors and the dielectric resistance is frequency dependent, which I can easily represent it through Ansys, putting directly the expression where frequency is a variable.
      This is good for me, by the way I need to export spice files like '.lib', when we make the equivalent circuit in Q3D, I know that there is a tool that allow us to take spice files directly, but this is not the case. I'm making the circuit directly in simplorer/ circuit environment.
      I've already tried to copy and translate the netlist to LTSpice, and there I would generate the lib files, but I've not been successful until now.
      Which alternative do we got?
    • Praneeth
      The answer for this post is being provided under the following link How to export a '.lib' (spice) file from a circuit in simplorer/ circuit? ÔÇö Ansys Learning Forum.
      I am closing this thread. Please do not create duplicate posts in the forum going forward.
      Thanks.
