November 23, 2020 at 5:20 am
Mushtaq
SubscriberI want to Post process the ANSYS FLUENT data files into open source CFD post processing software Paraview instead of using CFD-Post software. Can Anyone here guide me step by step procedure of how to export FLUENT data to paraview. -
November 23, 2020 at 11:23 am
Forum ModeratorLook in File-Export and see what's available. You may need to try in Serial and check the limitations for Paraview as some formats are only available for nonhanging node meshes etc. n -
July 6, 2023 at 10:46 am
ehsan.sadeghi
SubscriberIt is quite an old post but i am writing it here for anyone who has the same question. 1-Export it in ensight gold format 2-in the .encas file remove the last two lines and all the quotation marks 3-change the extension to .case
- The topic ‘How to export ANSYS FLUENT Data to Paraview?’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3151
1680
1470
