TAGGED: displacement, export-result, harmonic-analysis
February 7, 2021 at 12:40 pm
mohammedlaminemekhalfia
SubscriberDearnnI used harmonic analysis to study the effect of a harmonic force on a plate, Now I would like to ave the results in a table format? ( Displacement by frequency value)nI would like also to have ( displacement by time) is that possible????. -
February 8, 2021 at 6:04 am
1shan
Ansys EmployeenYou could do this by right clicking on the result (lets say deformation) -> export. Check out this video . For displacement vs time you will have to perform a transient structural analysis instead of a harmonic analysis.nRegards,nIshann -
February 14, 2021 at 10:50 pm
SubscriberDear Sir I performed Modal superposition with transient yet I am having some problem.nI am working on analysis of a plate, I added a transient to collect deformation by time due to a force impactnI wanna ask two questions:nthe first I added a tabular (time) yet I am having 456 pts while I am using only 266 as input.( have only 266 value of force)nthen I would like that my input get repited for 2 or 3 timen -
February 15, 2021 at 9:23 am
SubscriberDear Sir I performed Modal superposition with transient yet I am having some problem.nnI compiled my forced value to get a tabular form so I can insert it in transient ( I have only 226 value) yet when I input them I get more. even for the stepnhow to do? shall I use full transient ( transient only) ? is that will influence the accuracy of the reults?.nnn
February 16, 2021 at 10:59 am
1shan
Ansys Employee,nSorry for the late reply. I am not very clear about what you are asking. I assume that you have 456 data points but you are just being able to add 226. Is that the query? If so you could try this setting - Number of steps=1, Current step=1, Step end time=456 s, time step=1. This will generate 456 data points. Also if you want to add a sine function you could directly do so by clicking on the arrow next to Magnitude -> function = sin(time)Regards,nIshan.n -
February 24, 2021 at 11:19 am
SubscribernMy quest was ..... I have a tabular data (Force(time)) ....time is varying for 0-10s with. so I registred 226 points (f,t) in this table.nwould you please help me with the settings? n
3363
2471
1310
1022
