LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
How to export k file in ANSYS Multiphysics/LS-DYNA 2020R2 Version?
    • pengchengyin
      Hi all,
      As the title, How to export a k file in ANSYS Multiphysics/LS-DYNA 2020R2 Version? I remember the way that how to export k file in old version, which is Main Menu -> Solution -> Write k file. However, I didn't find this option in the 2020R2 version. Does anyone can tell me how to export the k file in 2020R2 version?
    • Samir Kadam
      nHope you are doing great!! nLooking at the image you attached, it seems like Mechanical APDL tree outline. Can you please clarify if you are looking for exporting *.k file from APDL interface? nIf you want to export it from the WB interface then, you can do it using Write Solver File under LS-DYNA Pre ribbon, when you click on LS-DYNA in the tree outline. Please refer to following image. nI hope this helps. Please let us know how it works. nRegards,nSamir.n
