June 23, 2022 at 3:43 pm
amando.gallardo
SubscriberHello, Maybe this topic is already answered, but I found no info about this in the forum...
So, How can I export 2D/1D features (points, lines, surfaces) from spaceclaim to workbench. I know there are some options to check inside geometry properties before start any design:
Solid Bodies, Surface Bodies, Line Bodies, and the Mixed Import Resolution: Solid, Surface and Line.
However even checking these options nothing is exported to workbench, actually an attach error comes out when I try to open the model.
Thanks for your comments!
July 6, 2022 at 12:28 pm
Sahil Sura
Ansys EmployeeHi @amando.gallardo,
Setting the analysis type to 2D from the properties might be helpful.
You can also use the Project command to project the features on surfaces or solids.
Assigning a cross-section to a line body in SpaceClaim itself makes it easy for the user to visualize in mechanical.
The following video may be helpful for the same-
You can also get more details on Body Filtering property and Mixed import resolution from the following references-
General Information (ansys.com)
Mixed Import Resolution (ansys.com)Solutions to some of the errors can also be found in Problem Situations (ansys.com).
Hope that helps!
Thanks,
Sahil
January 9, 2023 at 10:24 pm
amando.gallardo
SubscriberHi Sahil,
Thanks a lot for your reply, I was having troubles with my account.
Really appreaciatte your support :D
Hello amando,
Will you please share details of error may be though screenshot image attachment so that we will be able to get more clarity. Based on error details we may be in a position to provide some suggestions.
Thanks
3778
2573
1825
1242
598
