How to export many result objecs at once
    • b.x. Yang
    • HarsihilZLHZ
      Write apdl script to export datan
    • b.x. Yang
      @Hars.nThank you for replying. nYou saying insert a command in solution part?n
    • HarsihilZLHZ
      I have attached example. This below scirpt you can paste in solution using commands(APDL).nnYou need to modify as per your Model!!!!nI have selected all nodes but you can select particular body or face and can do named selection for this body or face.nnThan you need to select particular Named Selection and apply *Get commmandnnSET,LASTn*GET,my_numnode,NODE,0,COUNTn*DIM,DN,array,my_numnode,2n*DO,i,1,my_numnoden  *GET,my_all,Node,i,S,Zn   DN(i,1) = i  t   t   n   DN(i,2) = my_alltn*ENDDOnn*CFOPEN,gantry1,txt,C:\Users\Harshil\Desktop\Gantryn*vwrite, DN(1,1),DN(1,2)n(4x,' ', F6.0,4x,' ',G15.8,4x)n*CFCLOSEnn
    • b.x. Yang
      Thank you very much, again!nI'll try it.n
Viewing 4 reply threads
