March 21, 2021 at 5:22 am
bondhanansys
SubscriberHello, Sir.
I use Spaceclaim 2021R1, everything is good performance. I already finished my technical draw with Spaceclaim. The I try to export to PDF and image by choosing "Save as" but the only one choice is *sdoc* file type.
Would you tell me how to export the technical draw to pdf and image from Spaceclaim?
March 22, 2021 at 4:21 amKeyur Kanade
Ansys EmployeeIt may not be available for student version. You may take print screen. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 22, 2021 at 4:26 ambondhanansys
SubscriberThank you, Sir.nViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
