June 21, 2018 at 10:26 am
konne89
SubscriberHow can I get the mass matrix from a superelement? For the stiffness
matrix that works without problems, but I try it in the same way for
the mass matrix and it doesn't work.
I work wtih Ansys Workbench and add some Commands. -
June 21, 2018 at 2:24 pm
Sandeep Medikonda
Ansys EmployeeHi,
Yes it is possible to retrieve the mass matrix from the .sub file using the HBMAT command. Please look up this command in the manual.
Just note that this particular command only works in the /aux2 module.
Sandeep
June 21, 2018 at 4:15 pm
konne89
SubscriberSolved it! You've to implement a command in the Solution in Workbench. Below is my source code:
fini
/filname,myse ! name of the super element
/solu
antype,substr ! analysis type: substructure
seopt,myse,2 ! saves mass and stiffness matrix
m,all,all ! creates master nodes
solve
fini
/AUX2
FILE,myse,sub
HBMAT,aux2_stiffmatrix, txt,,ASCII,STIFF,YES,YES
FINISH
/AUX2
FILE,myse,sub
HBMAT,aux2_massmatrix, txt,,ASCII,MASS,YES,YES
FINISH
3285
2467
