How to export/write the whole result of a periodic model via one period result?
    • Justasimplecfdguy
      All,
      I modeled 1/16 (22.5 degree) of my cylindrical domain (used periodic boundary condition). In Fluent, I am able to see the whole domain by going to "View" section as well as having the pressure distribution on my whole domain (pressure distribution is repeated every 22.5 degree)
      I want to extract the pressure values on a surface of my domain and then apply that pressure distribution on a surface of my full domain (full domain that I have from the initial geometry before cutting it into 16 segments). How can I do it?
      In Fluent, I tried to extract all points and pressure values. However, It does not let me. It is just a visualization feature and does not make any physical nodes in the text or CSV file.
      Thank you in advance!
    • raul.raghav
      Depending on what you're trying, there is an easy way of doing it. Where is the surface that you want to define the pressure distribution located? Can you provide a simple schematic of the geometry with the surface?
    • CFDisGreat
      It is Justasimplecfdguy!
      I am afraid that I can not share a pic... I made a name selection in WB as a wall.
       I want to extract pressure and X-Y-Z coordinates for my mesh on that mentioned wall and later for 360 degree (a full 3D surface with zero thickness).
    • CFDisGreat
      I did search for it online. I was told to rotate my domain 8 times (8*45) and then append the cas/dat files to make a full 360 domain.
       I have difficulties when I wanna rotate the cas and dat files simultaneously.
       Any information how to use slit-periodic in FLUENT?
      /mesh/modify-zones/slit-periodic
      /mesh/modify-zones/fuse-face-zones
    • raul.raghav
      Justasimplecfdguy forgot his password?
      I was expecting (or should I say hoping) that you wanted to map pressure data on the wall. I also have one more follow up question: how is the pressure distribution on the wall? Does it vary only along the X-direction (flow direction)?
    • CFDisGreat
      I did
      I asked for a permission to share a pic.
      What is wrong with my account?!
      I want to upload a pic but can not do it. It says only JPEG or PNG files while my file is in PNG/JPEG format.
      I think the answer is no as pressure values change with X and Y.
      Thanks
    • CFDisGreat
      What am I missing when I use slit-periodic?
      In the new cas.dat file:
      I have "name"-periodic ---> symmetry
      interface 1---> interface
      interface 2---> interface
      "name"-side1-wall-interface-1 ---> wall
      "name"-side1-wall-interface-2 ---> wall
      In the old cas.dat file:
      I have "name"-periodic ---> periodic
      I think I need to fix this before rotating the mesh. Correct?
    • raul.raghav
      Honestly, a picture would make it a lot easier . Did you try attaching it to a post that you've already made?
Viewing 7 reply threads
