February 14, 2022 at 12:16 pm
mac_114
SubscriberFebruary 15, 2022 at 10:29 amKeyur Kanade
Ansys EmployeeThis looks faceted data.
You can use reverse engineering tools in SpaceClaim to create geometry.
Discovery SpaceClaim: Reverse Engineering/Modeling - SpaceClaim Tutorials - Ansys Discovery Forum
Or
you can check Fluent Meshing which works with faceted data to generate mesh.
Please go through help manual for more details
Regards Keyur
March 1, 2022 at 8:16 ammac_114
SubscriberThanks, I did it using ANSYS FMW.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2564
2074
1289
1106
459
