December 15, 2022 at 12:33 pm
kevin delabre
SubscriberHello everyone.
I am doing a simulation where I need to switch from a 2D axisymetrical problem to a 3D problem. This simulation is done in a classic static structural box. To do so, I am using the MAP3DTO3D command as specified in the ansys advanced guide help. As it turns out, after using the command which works, it seems that I can't use the graphic interface anymore and everything needs to be done using APDL command. Is it normal or is there a way to switch back to the ansys interface.
Moreover, I tried to extract the results to a new static structural box using inistate but it won't export the 3D solution (only the 2D one from the beginning).
What should I do to solve this problem, is there any document showing how to please ?
Thanks a lot. -
December 16, 2022 at 9:18 am
bhagwantP
Ansys EmployeeHello Kevin,
We have few examples in workbench technology showcase guide as well as in Ansys APDL verfication manual where it emloys above command.
Will youm please check out those if they are sufficing your needs.
Thanks
December 20, 2022 at 8:53 am
kevin delabre
SubscriberHello
Thanks for your answer. I tried to look inside but I couldn't find the right model, but maybe I haven't checked enough so I'll try again.
Just in case if you know where I could find the exemples i need, it would be much appreciated.
Thanks a lot.
December 21, 2022 at 1:37 pm
bhagwantP
Ansys EmployeeCiting few examples if in case you have access to all:
56.7. Results and Discussion (ansys.com)
1.5. Example: 2D to 3D Analysis of a Simple Threaded Connection (ansys.com)
4.3. 2D to 3D Analysis (Extruding the 2D Tire Model to 3D) (ansys.com)
Thanks
December 28, 2022 at 11:42 am
bhagwantP
I have cited some the links in this regards. Hope these links help you well.
January 3, 2023 at 7:50 am
kevin delabre
SubscriberHello,
Thanks a lot for your exemples. Unfortunately, it was public holiday and the company was closed so i couldn't have a look at them. I will now be able to do so and come back to you after I studied them carefully.
Thank you.
2066
1285
1104
459
