March 7, 2022 at 11:36 am
yeje2007
Subscriberhello all,
I want to know transient temperature data from points what I want.
Export data to Excel file.
I want to see node number, coordinate, time(1s~600s), temperature.
Please Help me .
It's my cold storage model temperature volume rendering.
file name is time.
March 7, 2022 at 2:41 pmRob
Ansys EmployeeAs staff are not permitted to open attachments, and I don't know which solver you're using I can't really help. More information may mean that I/we can.
March 8, 2022 at 2:55 amyeje2007
SubscriberThank you for the reply
I used Fluid Flow (Fluent).
This is my boundary conditions
Inlet -> velocity: 4 m/s, temperature: 278 K
wall -> Convection-> free stream temperature: 298 K, Heat Transfer Coefficient:0.027 W/(m^2 K)
Interior Temperature: 298 K
Rob, Thank you so much.
I don't know how to express my gratitude
1 seconds
20 seconds
10 seconds
March 8, 2022 at 9:37 amRob
Ansys EmployeeWe normally use contours to show things, the above plots prove you have a result but aren't overly helpful when working out what's going on. Have a look in the Results tab (ribbon menu at top) and you'll see a surface create tool. Points, lines and I'd use iso-surface of mesh coordinate are then used to get a location to take data: or use the walls etc. If you want to export the cell data have a look in File>Export for ASCII or Domain-Profiles for meshed surface data.
If you do a few tutorials the above functions are covered.
March 8, 2022 at 11:31 amDrAmine
Ansys EmployeeASCII Export is the way to go to have file every N time steps.
Viewing 4 reply threads- You must be logged in to reply to this topic.
2656
2120
1347
1118
461
