June 16, 2022 at 7:03 am
fanlu.zhang
SubscriberHi there
In this model "https://optics.ansys.com/hc/en-us/articles/360042761893-GaAs-pin-diode",
we can visualize the 2D electron/hole densities in the software.
However, when I tried to extract the electron/hole densities data, "Charge-Visualize-charge-n-View Data", it presents a "3529 x 5" matrix, as attached Image1.
In this matrix, it presents electron densities at 5 different voltages. For a particular voltage, it would be a matrix of "3529 x 1". We can not extract/plot the 2D electron densities with this "3529 x 1" matric, as it lost x,y information.
Could you please help to extract the 2D electron densities data? Thank you very much.
June 16, 2022 at 5:58 pm
Guilin Sun
Ansys EmployeeFor each set of the 3529 data, you will need to interpolate the triangle mesh to reclinear mesh. Please refer this link https://optics.ansys.com/hc/en-us/articles/360034405774-interptri-Script-command
- Error on Lumerical device
3862
2639
1859
1254
600
