April 15, 2022 at 12:51 pm
sirusblack07
SubscriberI would like to extract the mass property values using scripting in SpaceClaim for a specfic body selection.
Thanks,
April 19, 2022 at 12:12 pmAniket
Ansys EmployeeWhich of the mass properties are you looking for?
-Aniket
April 19, 2022 at 2:03 pmErik Kostson
Ansys EmployeeTo get volume of a part on the tree see this:
volume = GetRootPart().Bodies[0].Shape.Volume
Also the MeasureHelper functionality can help with that.
selection = BodySelection.Create(GetRootPart().Bodies[0])
volProps = MeasureHelper.MeasureVolume(selection)
To get mass with MeasureHelper one needs to assign density (properties) to the part in question.
Then one can use the MeasureHelper GetMassProperties method to get the information.
All this can be recorded via the UI and them the above calls will be visible.
Search the forum and the internet to see how to record SC scripts.
All the best
Erik
May 19, 2022 at 12:33 pmFirasBejar
SubscriberThank you that solved my issue
RegardsViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8782
4658
3151
1678
1468
