TAGGED: aerodynamics, formulacar, geometry-clean-up, spaceclaim
May 1, 2023 at 3:27 pm
amirmohammad.rajabi
SubscriberHello,
I'm in the process of preparing a formula car geometry for simulation. The problem that I have is that different parts of the body are separate since the original design was inteded to showcase an assembly. As a result I'm dealing with a complex body work. The main problem is that the body is hollow as it can be seen in the picture. Since my simulation only deals with external aerodynamics, I don't need the inside of the body and want to have filled body. I'm would like to know if there is any way I can fill the body since it is made up of many surfaces with different anlgles and curvatures. Any help is greatly appriciated. Thanks in advance.
May 2, 2023 at 5:11 am
Keyur Kanade
Ansys EmployeeYou will need to creat as well as modify the current geometry. Please go through tutorials in SpaceClaim.
SpaceClaim Tutorials - Online Learning - Ansys Discovery Forum
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5364
3363
2471
1310
1018
