how to find average power of output port
    • park0415
      hello,
      I already know how to check port power by using poynting vector.
    • Praneeth
      nYes, you can form relevant expression using field calculator to calculate the average power.nBest Regards,nn
    • park0415
      Thanks! nPlease, can you tell me the formula or method by using field calculator?.Regards,nPark0415n
    • Praneeth
      Hi,nKindly go through Using the Fields Calculator section of the HFSS Help document for more detailed information for your need.nAll the very best.nBest Regards,n
Viewing 3 reply threads
