How to find node numbers in ansys apdl
    • OnurOnder
      Have a nice day. I am trying to prepare a code on Ansys Commands (APDL). Thanks to this code, I am trying to pass the node numbers on the whole body to an array (actually I want to see these values on a txt). I found some codes on the internet. Based on these, I tried to create my own code. However, the code I wrote is not working properly. Can you help with this?
    • Govindan Nagappan
      Can you copy paste the code you have now?
      Can you attach an image that shows s sample output you need?
