How to find number of elements and elment faces in a model?
    • abhishek2011
      While modeling a reinforced concrete beams ee need bond concrete with reinforcement so for the commands we need number of elements and element faces.
    • Erik Kostson
      As I promised below is the recommended workflow which does not need any commands anymore for modelling reinforced concrete:
      All the best
      Erik
    • abhishek2011
      Thanks a lot Sir
    • abhishek2011
      Sir I'm not getting model type option under definition of the solid material. And also how to give edge sizing?
    • Erik Kostson
      Can you please insert an image and show these options (is it for a solid) - thank you
      Have in mind that in the slide where the reinforcement is defined under model type (slide 6 ) that is for a line body/beam so not a 3D solid part
      Erik
    • abhishek2011
      I got it sir , I had given solid body now i changed it to
    • Erik Kostson
      Great - I will close this one, but if you have an other questions please open up a new post.
      Thank you
Viewing 6 reply threads
