November 10, 2020 at 2:24 pm
Sumit_vjti
SubscriberI'm working on simulation of SAVONIOUS Vertical axis wind turbine (VAWT) using 6DOF dynamic Mesh technique.My simulation is working correctly, but the problem is I can't find how to get the rpm of the turbine.nIf anybody know how to get rpm or angular kindly help.nThanks in advancen -
November 10, 2020 at 2:46 pm
Forum ModeratorThe solver knows the cell velocity so you just need to report either a function of x (y, or z) position of a cell or cells. n -
November 10, 2020 at 3:24 pm
Sumit_vjti
SubscriberThanks for reply.nI searched the report defination option but couldn't find the option report the cell velocity.n n -
November 10, 2020 at 3:40 pm
November 11, 2020 at 3:45 am
Sumit_vjti
SubscriberThanks for the help.nAs far as my understanding you are saying that I will have to create point on rotor which is function of X,Y and time. correct?n -
November 11, 2020 at 9:34 am
Forum ModeratorNot quite. A point won't travel with the rotor. You will need to separate out a facet and report on that. n
- The topic ‘How to find out RPM of turbine’ is closed to new replies.
- Using GPU in FLUENT
8808
4658
3151
1680
1470
