October 7, 2023 at 3:24 am
Coulson Jiang
SubscriberI'm doing the inverse design by using the lumopt package, and I want to check the function-"topoparamstoindex" in Lumerical which I think is important to my work, how to ind the built-in function script of Lumerical and modify it ? Any advice will be appreciated.
October 10, 2023 at 6:49 pm
Amrita Pati
Ansys EmployeeHi Coulson,
I am afraid the code is internal and can not be shared. But I will confirm that with my collgeaues and get back to you.
Amrita -
October 10, 2023 at 9:51 pm
Amrita Pati
I confirmed it with my collegeaue. Sorry, the code is meant to be internal and can not be shared with the customer and therefore can not be modified by the customer as well.
Amrita
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
