Platform
Platform
How to find the face number on HFSS model
    • Thomas Rodriguez
      I am trying to run a script that builds a transistor and assigns an excitation to one of the faces of a box (there are a few boxes that need an excitation, but I want to get one working before I add the others). However, whenever I try to run the code, I get an error that that FaceID is incorrect. When I try to look up the FaceID of all the objects, the numbers are getting bigger each time I run the code. So the code has to change each time, which confuses me.
      I delete all the objects on the HFSS model before I run the script everytime so that I can see my device being built each time. What should I do fix this issue? This is a big bottleneck for my work.
Viewing 0 reply threads
