November 5, 2018 at 7:41 am
nagesh56
SubscriberI am trying to simulate the two-phase thermosyphon heat pipe by using the lee model of evaporation and condensation in the how to fix the values of evaporation and condensation frequencies.I left it as default and done the simulation but at the condenser, it is rejecting more heat compared to the heat input given at evaporator section. I don't know how to fix this problem it this is the reason for more rejection at condenser or any other parameters I need to check?
Edit: rwoolhou. Move to Fluids.
November 5, 2018 at 11:36 am
Ansys EmployeeCheck for convergence too: you may find that you've not got an accurate calculation. This assumes the mesh is also sufficiently resolved to give a good result. Re those defaults, you'd need to decide whether they're suitable for your model.
November 5, 2018 at 11:41 am
nagesh56
Subscriberyes, I created a fine mesh of 40K elements. and all my boundary conditions are fine, still, I am finding this problem.
November 5, 2018 at 11:56 am
DrAmine
Ansys EmployeeThe coefficients are not derived from principles. You need to have some references, experimental data or machine learning to find the best suitable coefficients. have a fun!
November 5, 2018 at 12:06 pm
nagesh56
SubscriberAtleast tell us how to guess the values depending on our operating conditions. As of now we don't have any experimental results. -
November 5, 2018 at 12:20 pm
DrAmine
Ansys EmployeeIf you do not know anything then it is hard. It is case dependent. Generally the evap frequency can bet set 10 times larger the condensation one but as I said it requires tuning from your side as it is a "MODEL" and not the "REALITY".
November 7, 2018 at 4:33 am
nagesh56
Subscribermy operating conditions are operating pressure 20kpa and corresponding saturation temperature is 60 C, the heater is at a constant temperature of 340 K and condenser is at a constant temperature of 300 K. So for these conditions can you suggest some guess values.
November 7, 2018 at 7:09 am
DrAmine
Ansys EmployeeSee previous posts.
January 22, 2021 at 10:33 am
Nitin_Bansal
Subscriberhello
are you able to come over to your problem?
if yes then please help me out because i am facing the same problem .
thanks
January 22, 2021 at 1:50 pm
Karthik R
Administrator
If your question is related to the coefficients in the Lee model, please refer to the literature to understand what range of values are applicable for the working fluid as well as the conditions you are attempting to model. As mentioned by this is a tuning parameter and generally needs to come from experiments.
If you are having modeling issues, please create a new post and provide some details about these issues and we'll help you.
Thanks.
Karthik
January 22, 2021 at 4:02 pm
Ansys EmployeeAs you've already done https://forum.ansys.com/discussion/23790/lee-model-implementation-for-different-fluid#latest
Locking current thread.
2532
2066
1285
1104
459
