November 28, 2022 at 6:14 pm
jannatul nayem
Subscriber -
November 29, 2022 at 6:27 pm
Guilin Sun
Ansys EmployeeI cold not see the content and the device structure. If this is for FDTD simulation, you can add a mode source, or a port, and then to choose "user select" to find the correct mode. Please try.
- Error on Lumerical device
2656
2120
1347
1118
461
