August 10, 2019 at 5:46 am
semi
SubscriberI am using ANSYS Fluent, Mixture model for air-water two-phase flow in T Junction.
I want to find the time-averaged mass flow rate of water and air at the outlet for 5 seconds.
Right now I am writing the mass flow rate of air-water in the output text file and then averaging it in the EXCEL.
But, I could not understand, Is it ok are not?
August 12, 2019 at 10:56 am
Ansys EmployeeThat's how I'd do it. There are time average options but, without checking, I can't remember if they extend to reports.
January 6, 2020 at 8:30 am
January 29, 2021 at 8:09 pm
umair221143
SubscriberDear semi, nCan you please explain how you solved this issue?n -
January 30, 2021 at 12:20 pm
Karthik R
AdministratornAs mentioned by make sure you write out your variable of interest as a text file. You can do this from the Report menu - using the write option. nOnce you do this, read this data into Excel and then start manipulating to average in time.nKarthikn
2726
2146
1357
1150
462
