April 29, 2022 at 3:11 pm
manelaero2020
SubscriberHi friends
I am using fluent 2019 r2, the option 'prevent reverse flow' doesn't exist in this version.
My questions :
1- How to fix reverse flow using fluent 2019 r2?
2- I have read such solutions as refining mesh at the outlet/using coupled solver / extending the outlet furthermore (not possible for me) / and decreasing under relaxation factor
I have decreased under relaxation factor of pressure and momentum to 0.4 and of turbulence to 0.7
But I don't have an idea if this solution can affect solution accuracy; do you have an idea if this can affect solution accuracy please :)?
thank you a lot
all my kind regards
April 29, 2022 at 4:05 pmRob
Forum ModeratorYou identify why it's happening and work from there. The flag to prevent reverse flow shouldn't really be used without understanding the flow as you might be forcing a non-physical result.
Viewing 1 reply thread- The topic ‘how to fix reverse flow in Ansys fluent 2019 r2’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3151
1680
1470
