Ansys Products
Ansys Products
How to fix RSS is disabled (ansys 2021 r1)
    • HexaCyber
      it always fails when RSS is disabled showed up
      needs help!!!😫
    • HexaCyber
      detail progress log
      Jun 05, 2021 10:25: Output from ANSYS, Inc. Silent Licensing Client Installation Configuration run during Release 2021 R1 installation:
      Hostname: MSI
      Installation directory: C:\Program Files\ANSYS Inc\ANSYS Student
      Current date and time: Jun 05, 2021 - 10:24
      __________________________________________________________________________________________________________________________
      ***** Your machine will now be configured to run the products that you installed *****
      Checking to see if there are any client-related files that need to be moved from the update directory
      to their permanent locations...
      Checking to see if existing lmutil executable should be replaced...
      lmutil executable in the update directory is not newer than the file in the winx64 directory.
      Therefore, this file will not be replaced, and the file in the update directory will be deleted.
      Checking to see if existing hasp_rt executable should be replaced...
      hasp_rt executable in the update directory is not newer than the file in the winx64 directory.
      Checking to see if existing ANSYS Licensing Interconnect Client (ansysli_client) executable should be replaced...
      ===> ERROR: The version value returned for the file in the winx64 platform directory
      does not have the correct format, which is x.y.z.The value returned was the following:
      Messages file C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\language\zh\ansysli_msgs.xml does not exist.
      2.2.1
      Therefore, no action will be taken.
