November 1, 2022 at 8:52 pm
Newton Duarte
SubscriberGood afternoon. So, I am producing a simulation, where the objective is to evaluate the flow of a system composed of two phases where one of them is continuous and the other formed by particles, through a composite geometry by a viewer. Within this evaluation, the percentage of particles that interact with the wall (display) that corresponds to this viewer. Within the setup step, a multiphase model (Eulerian), laminar viscosity, and the discrete phase was selected as granular, simulating the particles of the system. From what was understood based on the tutorial and on the forums with DPM in Ansys Fluent, capable of simulating a flow of particles, there are present in another continuous phase, having thus, a multiphase flow, where the goals set are not linked only to a graphic result, but a result attributed to the calculation, which is desired to be carried out. This is because, our objective is to evaluate the possibility of understanding the interaction of particles with a simulation applied in the simulation, accounting for the geometry of the interaction that can interact with a wall that is specified. However, at the moment in question, a divergence discontinuity occurs in the flow, providing an error during compilation, all output parameters and boundary conditions have already been verified based on the indicated tutorial as well. Attached is a PDF document, follows the steps of the process and comments some errors. So, I would like to count on your kind help to guide me out of the impasse and be able to move forward with the evaluation process.
November 2, 2022 at 4:23 am
Nikhil Narale
Ansys EmployeeHello, it is difficult to comment without knowing details of the setup. Can you please share:
- Screenshot of the residuals plot.
- Mesh screenshots and the mesh quality.
- Time step size.
- Solution methods (P-V coupling scheme) selected.
Looking forward to hearing back from you.
Nikhil
November 3, 2022 at 5:25 pm
Newton Duarte
SubscriberHi, thanks for the reply.
So, i have took the screenshots about the details of the setup.
Ps: The time step size was was modified in different variations, but the error persisted.- Solution methods (P-V coupling scheme) selected.
- Time step size and residuals plot:
- Mesh screenshots and the mesh quality:
- The topic ‘How to fix the floating point error?’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- obtaining pressure distribution by making points in ansys
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
8808
4658
3155
1688
1478
