December 6, 2019 at 7:32 am
Rosalinekavitha
SubscriberHi, i am trying to compute power transfer efficiency between coils using HFSS. When the Rxer coil sweeps coaxially (manual operation), i found the port is detached from terminals. In parametric set-up i have defined the coaxial sweep of coil between 10mm to 20mm. But for all values of sweep,there is no change in the value of mutual inductance.
Port is defined using rectangular sheet alone. [But i have tried wrap,imprint n creating polyine]. How to fix this issue?
- Maxwell, HFSS or Q3D?
- Error
5282
3299
2469
