How to form new part in SpaceClaim
    • I-Lun Chen
      Hi, I am new to SpaceClaim and would like to know how to form new part in SpaceClaim so that fluid will continue flowing in the bodies. I could do it in DesignModeler as in the picture below by right clicking the desired bodies. How can I do the same thing in SpaceClaim? Thanks.
    • Keyur Kanade
      In SpaceClaim, select bodies and use right click and then select create new component.
      Please go through help manual for more details
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
    • I-Lun Chen
      I tried this, making new component doesn't group them together in mesh as below, they are still separated.
      Ideally, I need them to be like below
    • Keyur Kanade
      Making new component in SpaceClaim should work here. Can you please insert SpaceClam image?
    • I-Lun Chen
    • Keyur Kanade
      Yes , it is correct.
      Are you using 'Share' option in Workbench tab?
    • I-Lun Chen
      Where can I check that?
      Thanks.
    • Keyur Kanade
      Under Workbench tab in SpaceClaim
    • I-Lun Chen
      I didn't use it.
    • Keyur Kanade
      Aslo make sure you use latest version.
    • I-Lun Chen
      I believe it is due to we don't have the license for DesignModeler. Thank you.
Viewing 10 reply threads
