March 15, 2021 at 7:12 pm
Saurabh1011
SubscriberSo I am meshing the one part of the larger assembly (Part geometry shown below)
March 16, 2021 at 1:04 pmKeyur Kanade
Ansys EmployeeYou may want to split the geometry at those places. nAlso use edge biasing. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 16, 2021 at 1:35 pmSaurabh1011
SubscribernYou may want to split the geometry at those places. Also use edge biasing. Please go through help manual for more details Regards,KeyurHow to access Ansys Online Help DocumentHow to show full resolution imageGuidelines on the Student CommunityHow to use Google to search within Ansys Student Communityhttps://forum.ansys.com/discussion/comment/111047#Comment_111047
Hi,nI already split the face into a semi-circle for the inlet. I can't split the volume since I have another part attached on the back side of the geometry. (Refer to the image below)nThose are the fins that are attached to the backside of the geometry. nCan you elaborate on edge biasing? on which edge should I use edge biasing? & how will it remove skewed elements?nAlso, can you post the link for ansys help manual?n
March 17, 2021 at 9:47 amKeyur Kanade
Ansys EmployeeWhat mesh method you are using? Please use patch confirming tetrhedron. nFrom latest image it seems it would require considerable geometry decomposition to get hex mesh in your geometyr. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2630
2110
1335
1110
461
