TAGGED: ansys-maxwell, digital-twins, parameters, twinbuilder
March 21, 2022 at 1:22 pm
RADIUMH
SubscriberMechnical has Static Rom and Dynamic Rom ACT, Fluent also has its own method.
How to generate "snapshot, doe.csv, setting.json, points.bin" file in Maxwell?
which could be used to build a digital twin model in Twin Builder.
Thanks!!
April 5, 2022 at 4:16 pmHDLI
Please see the examples in help manual. the link is https://ansyshelp.ansys.com/Views/Secured/Electronics/v221/en/home.htm#../Subsystems/TwinBuilder/Content/ANSYSExample4UsageofROMComponentsinTwinBuilder.htm?TocPath=Twin%2520Builder%257CTwin%2520Builder%2520Help%257CProduct%2520Coupling%257CStatic%2520ROM%2520Components%257CAnsys%2520Examples%257C_____4
We could also find some ROM examples in Ansys EM installation folder, C:\Program Files\AnsysEM\v221\Win64\Examples\Twin Builder\Applications\
HDLI
April 6, 2022 at 9:35 amRADIUMH
SubscriberThanks so much for answering my question. But Example4(Usage of ROM Components in Twin Builder) talks about regenerating snapshot file in Twin Builder, not generating based-data file for building ROM, and i think the model in Example4 use Static ROM ACT to generate this data file.
An ANSYS engineer told me maybe I coud output the X.Y.Z coordinates of each mesh point and the CSV table of the variables on the coordinate points. Through the python program, the data in the CSV table is compiled into the above format that the ROM reducer can use.
RADIUMH
May 15, 2022 at 5:06 amCollins_Jnr
Exporting Design Points to a CSV File (ansys.com)
This is a link that will help you create those files
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8754
4658
3151
1678
1454
