How to get a certain face through the curve of flow rate versus time.
    • h395523899
      What I know is to get relevant data on this surface by creating a surface report.
      However, I did not find out how to show the relationship between the volume m3 flowing over the surface and the time t.
      I only found that the flow m3 of the entire model can be set to change with time t in the volume report.
    • h395523899
    • Keyur Kanade
      Hello h395523899
      You can use Solving --> Reports --> Defintions --> New --> Surface Report --> Volume flow rate as shown in attached image.
      You can change the Frequency as per your requirement.
      Keyur
