December 4, 2020 at 2:05 pm
Prudviraj
SubscriberDear sir, I am beginner to the Ansys CFD....Currently I am working on Symmetrical domain using VOF water falling over the 2 cylinders (2 phases i.e water and air), but I am not getting proper results because of un structured mesh.. I request you please help and suggest for the attached domain how to get a structured mesh.....I have attached my unstructured mesh for your information.....
December 4, 2020 at 3:24 pmRob
Forum ModeratorThat mesh doesn't look too bad for the VOF model, more likely you've set something wrong in the solver. nDecember 7, 2020 at 2:59 amKeyur Kanade
Ansys EmployeeYes, mesh looks good for VOF. nIf you want to have structured mesh, you may try ICEM or following decoposition in SpaceCLaim or DesignModeler. nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
Trending discussions- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8762
4658
3151
1678
1456
