We have an exciting announcement about badges coming in May 2025. Until then, we will temporarily stop issuing new badges for course completions and certifications. However, all completions will be recorded and fulfilled after May 2025.
Topics related to Fluent, CFX, Turbogrid and more.
How to get average drag or lift coefficient values from fluctuating plot.
    • Sakib Abir
      I am trying to get drag average drag coefficient for a certain geometry at some certain Reynolds number. My drag and lift coefficient plots are stabilized with a fluctuation and after the simulation when i calculate the drag or lift coefficients it shows me the instantaneous value of the plot where the simulation stops. But I need to know the maximum, minimum and average drag or lift coefficient values from that fluctuating plots. Can anyone help me about this, please?
    • Amine Ben Hadj Ali
      1/Export the Report as Outfile and do post-processing outside of Fuent to get Max, Min and Average
      Or
      2/Store Forces in Cell Memories and do all in Point 1/ via User Defined Functions.
      • Sakib Abir
        Thank you very much for your reply sir. But I am very sorry I could not understand properly. It would be very helpful if you could kindly tell me in a bit details. Actually I am very new to ANSYS as well as in research and my work is stuck for this lack of information. I don't know from where I should export the reoprt as outfile. I am still searching for it.
      When creating Drag Report or Lift Report you have the option (and in the newst versions always selected) to write an out-file (text file) with the Drag and Lift Values vs time step or flow time. Please have a look into the help and search after Report Definition.
    • Sakib Abir
      Dear sir, Thank you very much. I found out how to create report.out file. And did you meant that I need to find out my desired max, min and avg. drag coefficient from the data on my own in Excel? I was finding if there is any built in option in  ANSYS where I can activate the option to calculate max, min or avg? I found there is force option in report definition from where i can just calculate instaneous drag or lift coefficients.
      As mentioned in my first message the only one option will be to the work using UDF to track the forces, the mean, minimum and maximum over time in Ansys Fluent.
Viewing 4 reply threads
  • The topic ‘How to get average drag or lift coefficient values from fluctuating plot.’ is closed to new replies.
