December 1, 2022 at 6:21 am
Anadi_Mondal
SubscriberHello,
Fluid flows over a cylindrical rod and the flow channel is annular. Then how can I calculate the average liquid temperature in the flow (axial) direction?
I am planning to simulate this considering a 2D axisymmetric problem. Moreover, is there any problem to use volumetric heat generation (W/m3) in 2D?
Anadi
December 1, 2022 at 11:41 am
Ansys EmployeeNo problems running 2d-axi, just read the documentation to understand the requirements and equivalent sector.
Average temperature along the axis is a little more complex as you'll need to find the mean at a series of positions. Have a look at surface reports.
December 5, 2022 at 4:05 am
Anadi_Mondal
SubscriberHello Rod,
I can get the average liquid temperature at the inlet and outlet using the surface reports. But, I am planning to get average temperatures in several locations along the flow direction. Can you give me any idea to get the average temperature?
Anadi
December 6, 2022 at 11:28 am
Ansys EmployeeYou'll need to use surface monitors, do a few tutorials as they'll be covered in those.
2656
2120
1347
1118
461
