How to get drag and lift coefficient in coupling system(FSI) on workbench
    • jil260
      It's an FSI simulation, so the usual report monitor in fluent may not be available. Is there any solution to obtain drag and lift force and coefficients? By the way, what is the default area for ansys to calculate the drag coefficient? Projected frontal area?
    • Raef.Kobeissi
      Regarding the area, there are 2 ways of calculating Cd, you can chose frontal projection or you can chose the whole wet area. Both are acceptable but obviously would give different Cd values.
    • DrAmine
      You can still make force reports on any walls even if coupled to another physics.
    • jil260
      Then how can I see the plot? On the fluent window or the coupling window?
    • DrAmine
      In Fluent like usual.
    • jil260
      But there are no plots in Fluent after the calculation is done. How to view the results?
Viewing 5 reply threads
