October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeHow to get existing part names from CAD to SpaceClaim?
October 17, 2017 at 9:24 am
Arun
Ansys EmployeeThe CAD part names, as they appear in CAD, will only be imported to Spaceclaim if the Direct Reader is configured under CAD Configuration Manager for that CAD. The Associative Interface will import as generic names such as Solid1, Solid2, etc. Another approach for this can be, go to File>>SpaceClaim Options>>File Options>>Workbench and here select "Always use SpaceClaim Reader when possible option. This option skips CAD configuration manager's setting and uses SpaceClaim's reader to read native CAD file
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2116
1339
1118
461
