February 28, 2017 at 9:10 am
Nikita
Ansys EmployeeHow do I get existing part names from my CAD system into ANSYS SpaceClaim?
September 29, 2017 at 11:57 pm
pgl
Ansys EmployeeThe CAD part names, as they appear in your CAD system, will only be imported to ANSYS SpaceClaim if the Direct Reader is configured under CAD Configuration Manager for that CAD system.
The Associative Interface will import as generic names such as Solid1, Solid2, etc.
Another approach for this can be, go to File>>SpaceClaim Options>>File Options>>Workbench and then select "Always use SpaceClaim Reader when possible" option. This option skips CAD configuration manager's setting and uses ANSYS SpaceClaim's reader to read native CAD file.
December 12, 2017 at 12:26 pm
priyanshuxd
SubscriberWell, I've got a similiar solution here and I'm sure, It will solve your CAD problem. You must check this if the problem still persists, I'll guide you personally.
December 12, 2017 at 12:39 pm
Subscriber@priyanshuxd, I deleted your link to a Pandora One music app blog, it is not appropriate on this site.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2718
2146
1357
1150
462
