May 31, 2022 at 2:32 pm
EngGhost
SubscriberHello I've successfully simulated the closure of a flapper non-return valve as illustrated.
The inlet velocity increases gradually with a specific acceleration.
The following UDF is used to specify the motion of the flapper:
#include "udf.h"
DEFINE_SDOF_PROPERTIES(flappers_motion, sdof_prop, dt, time, dtime)
Six_DOF_Object *sdof_obj = NULL;
sdof_prop[SDOF_MASS] = 2.73e-3; /* flapper's submerged weight */
sdof_prop[SDOF_IXX] = 2161.86e-9; /* around the hinge */
sdof_prop[SDOF_IYY] = 367.96e-9;
sdof_prop[SDOF_IZZ] = 2471.27e-9;
real m= sdof_prop[SDOF_MASS];
real L= 0.024479 ;
sdof_prop[SDOF_LOAD_M_X] = 0 ;
sdof_prop[SDOF_LOAD_M_Y] = 0.0;
sdof_prop[SDOF_LOAD_M_Z] = 0.0;
real th_deg = theta * 180 * 7 / 22 ; /* valve opening angle, in degree */
sdof_obj = Get_SDOF_Object(DT_PU_NAME(dt));
if (NULLP(sdof_obj))
/* Allocate_SDOF_Object must be called with the same name as the udf */
sdof_obj = Allocate_SDOF_Object(DT_PU_NAME(dt));
SDOFO_1DOF_R_P(sdof_obj) = TRUE; /*1DOF rotation*/
SDOFO_DIR(sdof_obj)[0] = 1.0;
SDOFO_DIR(sdof_obj)[1] = 0.0;
SDOFO_DIR(sdof_obj)[2] = 0.0;
SDOFO_CENTER_ROT(sdof_obj)[0] = 0.0;
SDOFO_CENTER_ROT(sdof_obj)[1] = 0.0;
SDOFO_CENTER_ROT(sdof_obj)[2] = 0.0;
SDOFO_CONS_P(sdof_obj) = TRUE; /* constrained motion */
if (SDOFO_CONS_P(sdof_obj))
SDOFO_LOC(sdof_obj) = 0.0;
SDOFO_MIN(sdof_obj) = -0.0349 ; /* min allowable angle */
SDOFO_MAX(sdof_obj) = 1.0471 ; /* max allowable angle */
SDOFO_INIT(sdof_obj) = SDOFO_LOC(sdof_obj);
SDOFO_LOC_N(sdof_obj) = SDOFO_LOC(sdof_obj);
But now I want to simulate the closure of the flapper, taking into account the friction at the flapper's hinge.
I tried to just assign the friction value to "sdof_prop[SDOF_LOAD_M_X]" ,but the flapper started to move backwards (opening) until the flow increases, which is not correct.
So I want to get the value of the hydrodynamic torque of the flapper, and compare it to the friction with some kind of "if statement" that may look like this:
real static_friction=.0.005;
real kinetic_friction=0.003;
real hydraulic_torque =??? ;
If (hydraulic_torque{
sdof_prop[SDOF_LOAD_M_X]=0
else
sdof_prop[SDOF_LOAD_M_X]=-1*kinetic_friction;
BUT THE PROBLEM IS :
I don't know the udf code that can get the actual value of the hydraulic_torque on the flapper to compare it to the friction value.
Your help is highly appreciated.
Thanks a lot in advance.
June 1, 2022 at 9:00 am
EngGhost
SubscriberAnyone can help?
June 28, 2022 at 8:34 pm
Surya Deb
Ansys EmployeeHello,
You might need to calculate the torque separately or inside an UDF. Check this link [https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/flu_udf/flu_udf_sec_define_cg_motion.html?q=compute_force_and].
The above link explains how to calculate pressure force on a body. This can be modifed to calculate torque as well.
SD
3744
2573
1809
1236
594
