October 26, 2023 at 8:47 pm
srocca
SubscriberHello,
I want to find the capacitance of a small micrometer-scale design I imported from a .gds file. I have a top gate and a bottom gate as gold, there are other gates but I removed them for now to simplify the model. There is a dielectric substrate between the gates.
The mesh does not converge even for the most coarse initial settings. The Energy Error is sufficiently low to converge but Delta Energy is never low enough. I have it at 1% Delta Energy. I let the number of passes reach 30 but at that point, the # of tetrahedrons is so large that my computer crashes. What are some things I can do to get the mesh to converge? I tried Curvilinear Meshing to all geometry but that did not work.
I repeated the same model in Q3Design and cannot get mesh convergence there either.
October 31, 2023 at 1:06 am
HDLI
Ansys EmployeeHello Srocca,
Could you show what are the excitation? What does geometry look like? Which Maxwell solver are you using? Thanks.
HDLI
October 31, 2023 at 10:28 pm
srocca
Subscriber -
November 1, 2023 at 3:41 pm
HDLI
Thanks. Do you have another voltage source like 0V or -1V? There is insulator or vaccum between two sources for the capacitor simulation.
HDLI
- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3151
1680
1470
