Preprocessing
Preprocessing
how to get no. of element and nodes of each part of assembly after meshing?
    • maurya
      i have 18 parts in assembly i want no. of element and no. of node created  for each part.
      please suggest
      thankyou
    • peteroznewman
      In Meshing or Mechanical, in the Outline window, expand the Geometry branch of the tree and click on one of the 18 parts you see. In the Details window below, expand the Statistics branch and you will see the Nodes and Elements for that part listed.
    • maurya
      thank you sir
    • maurya
      when i am replying you on another question its show above shown error.
      thank you
    • peteroznewman
      The website parses the textbox where we type our post and looks for embedded code that it tries to execute. Unfortunately, some of the text we type looks like code because it has a keyword, or parenthesis or equal signs, but it's not intended to be code so it does not compute and generates an error.
      I now select all the text and copy it to the clipboard before I hit Add Post, because sometimes all the text is lost and a blank post is created.
Viewing 4 reply threads
