August 31, 2023 at 9:59 pm
September 1, 2023 at 11:28 am
Rajeshwari Jadhav
Ansys EmployeeHi Sangeet,
Please launch the above licensing utility with admin rights.
September 16, 2023 at 5:43 am
Gossi Pgras
SubscriberThere could be several reasons why you're encountering installation errors while trying to install the Rangefinder app. Here are some steps you can take to troubleshoot and potentially resolve the issue:
- Check the compatibility of your device: Make sure that your device meets the minimum system requirements for the Rangefinder app. You can check the app's compatibility by visiting the app's page on the App Store or Google Play Store.
- Clear cache and data: Sometimes, clearing the cache and data of the app can help resolve installation issues. To do this, go to your device's settings > Storage > Internal Storage > Apps > Rangefinder > Clear Cache and Clear Data.
- Uninstall previous versions: If you have previously installed the Rangefinder app on your device, try uninstalling it before installing the latest version. This can help remove any conflicting files that might be causing the installation error.
- Update your operating system: Ensure that your device's operating system is up-to-date. Go to your device's settings > About Phone/Device > System Updates. If there's an update available, download and install it.
- Disable antivirus software: Temporarily disable any antivirus software on your device, as it may interfere with the installation process. Once the installation is complete, you can re-enable the antivirus software.
- Use a VPN: If none of the above steps work, try using a Virtual Private Network (VPN) to change your IP address and location. This can help bypass any geo-restrictions that might be preventing the installation.
- Contact support: If all else fails, contact the Rangefinder app's customer support team for further assistance. They may be able to provide additional troubleshooting steps or offer alternative solutions.
By following these steps, you should be able to resolve the installation error and successfully install the Rangefinder app on your device.
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
- Acoustics model in Ansys 18.1
7690
4484
2957
1435
1322
