November 22, 2020 at 1:45 pm
maria08
Subscriberhello, nI'm doing cavitation simulation using LES turbulent model.nIn the Fluent, we can plot the graphic of RMSE velocity magnitude (not only velocity but also for other parameters) base on the sampled LES results. However, as I checked, RMSE and RMS are two different concepts. nI checked the ANSYS Fluent Theory Guide. I only find RMS in instead of RMSE. Therefore, I am confused. Is RMSE in Fluent is the root mean square error of velocity or root mean square of velocity?nThank you.nn -
November 23, 2020 at 12:53 pm
DrAmine
Ansys EmployeeRoot Mean Square Error of X Velocity is actually what we understand under SQRT(mean(u'^2))n -
November 23, 2020 at 1:12 pm
maria08
SubscriberHow to obtain u' in LES fluent ?nThank you for advancen -
November 23, 2020 at 1:50 pm
DrAmine
Ansys EmployeeThat is what I posted RMSE X, Y and Z velocity. If you want to have another definition you will then build up your own variable.n
8762
4658
3151
1678
1456
