December 23, 2022 at 8:58 pm
w.k.sky.x
SubscriberHow can I get smooth mapping like figure below. I tested the optimization and sweeps function but it is not as smooth as the image from the other publications. I cannot run too many parameters because of high computational load for this simulation.
Zhang, Haojun, et al. "High polarization and fast modulation speed of dual wavelengths electroluminescence from semipolar (20-21) micro light-emitting diodes with indium tin oxide surface grating." Applied Physics Letters 117.18 (2020): 181105.
December 27, 2022 at 7:17 pm
Guilin Sun
Ansys EmployeeYou will need more sweep points from 60 to 100. Think how many points you used for wavelength.
- Error on Lumerical device
2524
2066
1279
1096
457
