March 16, 2022 at 5:30 pm
tomtranzebracom
SubscriberI Could NOT get any Help PDFs from the Pull-down Help from Ansys Electronics Desktop Student 2021. Please help!
March 16, 2022 at 5:54 pmPraneeth
Ansys EmployeeHi Please share the error message that you are getting while accessing these GSGs (Getting Started Guide).
Are you not able to see any pdfs as shown in the screen shot you have shared?
Did you observe any error messages during installation?
Can you un install the whole tool and re install by following the instructions given in the downloaded folder and see?
All the very best Praneeth.
March 16, 2022 at 5:59 pmtomtranzebracom
SubscriberHello I got the installation successfully (no errors!) and was/am be able to open tool and open some included Example. From Pull-down Help for Tutorial PDFs (listed), I could not get any beside getting the below error snip. Please let me know HOW to get Tutorial PDFs (if without PDFs, I have NO ideas how to use HFSS tool!)1 Thanks.
March 16, 2022 at 6:09 pmPraneeth
Were you able to access these Help pdf documents before?
Did you do any modifications to the tool recently?
Is it possible to uninstall it completely and try reinstalling it?
While installing make sure you do not change any default settings.
March 16, 2022 at 7:12 pmtomtranzebracom
SubscriberCan you try installing it at your side? then verify to see if you get same problem as of my case?
Thanks.
March 17, 2022 at 7:54 amPraneeth
I have verified at my end and was able to view the said pdf files successfully.
March 17, 2022 at 11:03 amRob
Ansys EmployeeJust to ask the "obvious" question, can you open any pdf's at present?
March 17, 2022 at 3:40 pmtomtranzebracom
SubscriberHello All
My laptop here has pdf reader tool Nitro Pro, and I am not sure why I got such error. I could not open any on list.
But from Ansys 's tech support response to check into C:\Program Files\AnsysEM\Ansys Student\v212\Win64\Help\HFSS\GSG, I then found those PDFs. Thanks very much for your help!
Regards Tom
Viewing 7 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to access the ANSYS Online Help
- search does not work.
- Discussion Creation Error
- Regarding not getting link of click “accepted answer”
- unable to open the saved ansys file.
- Images added to Posts are scaled UP and down
- Access to ANSYS Customer Portal?
- Access Denied Error When I Send Post
- ACP module does not start
- I can’t create a discussion again
2612
2088
1321
1108
459
