February 25, 2022 at 6:29 pm
nuaman98
SubscriberIt is written in the reference manual-results returned, "Conduction and valence band edge including strain, but not including quantum confinement effects".
How can I get the strain for each layer if I enable the "calculate strain" option.
March 2, 2022 at 7:10 pmKhashayar Ghaffari
Ansys EmployeeHi.
When the ÔÇ£calculate strainÔÇØ option is enabled the strain is automatically calculated by the solver based on the reference materials, using the lattice constants of different stacks. More detailed description on this, and adding strain to MQW in general, is provided in this article.
Best regards
- Error on Lumerical device
2620
2098
1327
1110
461
